L14M_T
THE JOYS OF A 1200cc
Jan 14, 2009
222
RCT, South Wales
If I drive my car about 10miles and turn the engine off and leave it 15+ minutes it wont start, it will only turn over. But as it happens a few times I experimented to see if I could eliminate the problem and found if I open the bonnet and release pressure off the coolant tank, give it a bit of throttle when turning it over somtimes it will start. But im not sure if im cooling the engine down by opening the bonnet or its a coolant system problem?? anyone ever hear or know of a problem like this in the past?? any help will be really appreciated as its driving me nuts! [:@]
check to see if the car purges the fuel system when you turn the ignition on! it might be the fuel pump relay! it can go at any time after a few years, if it doesnt purge( make that squirt noise when you turn the ignition on ) then its the relay, and if it does make the purge noise then try changing the fuel filter, it may be blocked as a next start point
Good luck mate :D
Good luck mate :D
ok thanks mate. Will do tommorow ill get her up on the ramp on my lunch, fingers crossed.
have you tried a coolant temperature sensor? they sometimes go wrong.
I think that you should get it scanned for stored faults or buy a cheap scan tool like the Gendan VAG one that I keep suggesting people that don't want or need VCDS buy and keep in the car. (I have both!)
