vickiistewart1
Hi
My car radio is stuck in safe mode
I know how to get to the part to enter the code, I just dont know the code
Could anyone help me out please
Seat Leon 1.4s
I have the serial number of the radio
Hi there. Try looking for the code under the ashtray, under the removable panel by the handbrake, or in the handbook. Failing that you could contact a seat dealer and see if they can find it, although that would only work if a previous owner hasn't changed it.
Without the code there is no way to unlock it, you will have to buy a aftermarket radio.
Sequence suggestions in manual and on many forums are garbage: this is exact process:
When display = SAFE (#)
Ignition off
Turn on radio for 1 hour: initial code appears
Using keypad enter for first digit by repeatedly pressing number 1
For second digit, repeatedly press number two, then do 3 and 4 similarly
Press PROG, radio comes on and works normally again.
Sometimes it’s on a sticker on the unit itself. Pull it out for o check. Otherwise as said it’s seat or a new unit.
Badger5 Custom Map + TIP,
3” Sustem, FMIC, Bosh 550’s,
BC Coilovers, ARB’s +loads more.
can anybody help me get a code for my radio the serail is \ sezaz2p0064866/
Try what Nick9-11 said above.
Never heard of it before but if it works then that’s huge for lots of people without a code on here.
Can’t hurt to try it. Let us all know if it works or not.
Sent from my iPad using Tapatalk Pro
If you’ve got the serial number then SEAT should be able to get your code, but you’ll have to go into them as they won’t give it over the phone
