TBA how to...
Taken from ross-tech
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 060
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Gaz - Dont suppose you have a the spare throttlebody laying around do you? I think mines stuffed and need to source a replacment one that i know works.
Cheers!
woohoo she now revs thanks 2 matt (jivejester) off here he came over and diagnosed it as there was no signal coming from the throttle body so tried another throttle body and was still the same then checked through the wirein loom and he found a wire that was chopped then we bypassed it around the loom started it up an it revved, all 2 do now is fit drive-shafts, brembo's, b&m quickshift and top up oil levels and i can finaly take it out, cheers matt
Benny- the other 1 i had was out of my written off cupra it seemed like it worked made all the same noises as the other 1 but it was not in the car jus plugged up to see if was the throttle body i could try it once i get time as my car is at my mums and im livin about 3 miles away with no car should be goin down through the week so ill try it then
