daves ibiza
hi guys after leaving my car alone this weekend as the mises bought her new car jump into it today and every time i pull off or turn it squeaks now last week i replaced all bushes in wishbones arb links and bushes top mounts top mount bearings spent alot of time and money on this and it sounds rough:wtf:. as anyone had this type of squeaks . when i pull off and turn . someone help this is doin my headin now lol. oh and iv had camber setup and balljoints changed . many thanks dave
check the rack mounting nuts, mine worked loose and it made a nasty squeeky noise. are all your bushes poly, if so did you lube them before fitting?
i used oem ones mate and yes i used loads of lube they wer a [:@] to fit .
and ive cheched all nuts and bolts the ones i took off anyway . nightmare
check steering rack bolts m8 worth a go mine was the same steering would pul little to left and these were loose and id never touched them before this
I had a similar problem with my S3 worse first thing and on roundabouts and it turned out to be the power steering pump
Stuart
its only come about intill i changed alot of bushes on front top mounts ect
just had a thought, did you tighten the wishbone bolt when the car was on the ground? if not, crack them off and tighten again.
this is probably silly what im going to suggest. if it is a lound squeaky squealing noise would it be the fanbelt needing tightened.
no i mean did you tighten the bolts with the car on its wheels or in the air? if in the air, crack the bolts loose now its on the ground and nip them back up :)
fan belt tight. yeah mate i tightend bolts when car was in the air . so crack them on ground yeah . cheers mate.
would it mess camber up:(
yep crack off and do em up again! reason is if you do em up in the air it puts preload on the bush, which can lead to premature failure.
its possible camber might be off, if the camber was reset with worn bushes and now you have shiny new ones?
