cold start problem
I've often joked that I need to say "please" to get my car to start but lately the problem is getting much worse! the car had been sat since sunday (and snowed on 3 times) and I came to fire it up this afternoon and there was just no hint of life when turning it over. I took out the plugs and they were soaked in petrol (most likely from me hopelessly pressing the accelerator pedal!). I rested them on the inlet manifold so they had a path to earth and checked for sparks, they were all sparking as they should. so now I know I have sparks, petrol and hopefully compression so I just couldn't understand why it still wouldn't start! I gave the plugs a good clean and a spray with WD40 and also sprayed it in the plug holes. basically it took and hour of faffing around removing plugs, spraying with WD40, turning over with the plugs removed to get rid of the excess petrol and eventually it fired up! sounded like it was only on 3 cylinders for a minute or two then idled as it should. it has done this before but usually a good long crank would get it going. the car is a '97 16v gti. the plugs/leads/dizzy/oil/filter and cambelt are all new. any thoughts?
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
