alternator is charging as already tested voltage when running and its 14+
Then u got ur answer, battery is fine and that's charging, try the voltage drop test
Sent from my iPhone using T
im confused. I never queried charging. I am trying establish if batt is knackered or if it is draining too fast when not used.Then u got ur answer, battery is fine and that's charging, try the voltage drop test
Oh ok, cant really say ive paid enough attention but before even knew that fuel could leak into oil I had thought it was a bit thinner and discoloured compared to other times I checked. Cant really tell if can smell any fuel thoughLots of oils have a green tinge to them
everything appeared to go on and off with the ignition but posted the pic above to see if anyone couod confirm. worst case I will pull the fuse and see what happensI bet it u wired something on live wire on the drivers side fuse panel? And causing it to drain over night lil volts will add up daily
I still think its fuel related, if it was mine i would be checking the lift pump is doing its job properlyAll of the last comments are bit out of my depth.
Fuel pump - how do i disconnect the injectors to test as described There is a big electrical connector on the side of the head for the injectors - just disconnect it
Also how do I prevent the engine starting to check the starter as above
coolant temp sensor seems to show on torque app as described. Not suprising, was highly unlikely as would cause rough running and poor fuel economy rather than a fail to start
With regards to the injectors, how would I tell if there is fuel in the oil, I know that sounds stupid but cant help but think, when I checked the oil a couple of days ago, and wiped the dipstick on some tissue it seemed quite thin and had appeared to have a hint of green colour on the tissue. Not sure of its just be paranoid. Paranoia, fuel in the oil is obvious, and stinks, oil level would rise too
How do I do that. is that by pulling pipe and cranking to look for continuous fuelI still think its fuel related, if it was mine i would be checking the lift pump is doing its job properly
Right, I think I've checked this now. I again pulled off hose 1 and checked for flow but this time while cranking. There was flow but I wouldn't describe it as constant as such more pump pump pump as the engine cranked.I still think its fuel related, if it was mine i would be checking the lift pump is doing its job properly
It is jinxed, but it will be perfect by the time I've bloody fixed everythingSell the ****er haha. Lol.
