antnee
Firstly Ive done a search but cant really find the answer im after.
Ive traced the cable back and just as it goes under the carpet theres a rectangular connector, is this the standard connector?
Should there be a round connector as well? If so where?
Last question, On the headunit end what is the connector like?
I would also like a pic if anyone has one. I've a connecter in the boot, but it looks like a rectangle connecter that you use to connect speakers to a head unit, and not the round plug I've had on previous changers. Is this rectangle plug for the CD changer?
it is indeed the multi player plug . the vw/ audi changer has a fly lead coming off it with a rectangular socket
Yep, definately the rectangular one located drivers side wheelarch under the carpet. You should be able to push out 3 round holes for the fixing mountings for the VAG changer - although the fixing lugs are a right b*****d to fit!!
