Central Locking Faulty
PaddChas
Guys
I have a problem with the central locking on my 52 plate Leon Cupra. For some reason the remote fob has stopped operating everything except the drivers door?
Before I had to press unlock once for the drivers door and a second time in quick sucession to open the other doors and boot. Now I find that no matter how many times I press I can only open the drivers door.
Strange thing is that once I've opened the drivers door, I can use the unlock button inside the door by the electric window button to easily unlock the other doors - implies to motor and electrics is still functional?
Can you help?
Any ideas or help most appreciated
James
Jonesy
Leftie and Proud
Sep 27, 2004
420
Pig Hill
I had a similar prob not so long ago
Drivers door and boot would open but not passenger doors
then nothing worked
Was a real pain in the ar$e :censored:
Seat traced it down to a hairline crack in a fuse, took them ages to find it!!!
PaddChas
CupraSteve - don't think I have it enabled because i haven't changed anything and it just suddenly happened one day.. But can you tell me the procedure for checking this since I have VAG-COM so might as well
Jonesey - any idea which fuse?
Cheers guys
James
FezzR
disconnect the battery for 10 mins to reset the ecu and then recode the remote (requires) diag. machine
these ecu's seem to just get confused
