Changing Front Fog Lights
AdamC11
191
Bolton
Hi,
I'm looking to upgrade my Fog Lights to L.E.D's.
How do you access them and also any recommendations of L.E.D fog lights?
Adam
dieselface
647
Access via from wheel arch liner. You don't have to remove the wheel but helps with access. It's also a little fiddly with screw removal (if removing the unit like I was doing)
Sorry can't help with the LED bit.
dephead2004
918
12
I and others on here have successfully used mitec bulbs which are a good color match for the leds. There is a choice of color temps and no error messages and much cheaper £12 ish
Si FR
39
Isn't there a screw on the outside to remove the fog light assembly?
ma9mwah
201
depends on the model. S and SE are easy and can be done from the front. FR is from the back only, and if you have the extra large washer bottle then you almost have to disassemble the whole left front to change them over.
AdamC11
191
Bolton
Thanks for all the replies.
I have the SE model.
What type of tool do I need to remove the fog light cover?
Also, any guides available?
ma9mwah
201
AdamC11
191
Bolton
Thanks ma9mwah.
I will change them soon following that guide.
Slightly different question now.
I have a seat cupra metal footrest plate for the interior, im looking to attach it properly by using the using.
Im struggling to take of the plastic bit, which type of tool do I need?
Fmxvxx
387
Thanks ma9mwah.
There is a plastic 10mm bolt on the left and on the right side the clip just pulls off with a quick tug.
Fmxvxx
387
Thanks for the reply Fmxvxx.
It looks like a torx screw head on the plastic bit.
Would you mind taking a picture? all the previous foot guards rests I've done on the mk3 have been the combination I listed but I might be wrong Seat are very good at changing things around in MY's without saying anything.
Fmxvxx
387
Ah that bolt is on the side trim next to the foot rest (hard to tell from the closeness of the pic but it is indeed a torx bit t20 or t25 most likely a T20 bit.
Curtly
893
19
Essex
There's a couple of access panels to the rear lights, they might help?
Also has anyone got a link for these mtec bulbs?
Havsgaard
186
Denmark
I just tried to remove the screw at the front, beneath the fog lights, as mentioned above, but the plastic frame wont move. How hard did you pull it out? I didnt want to break anything :)
nokiauk
524
25
Edinburgh
I prised mine out with a screwdriver but wrapped round a cloth first and was very careful so as not to damage anything.
