Reactions: hamst
1. No... it would use less electricity so better :). (Bulbs are good as early warning of a flat battery as the headlights dip as well to the indicators :))
2. The resistor / capacitor business comes in if you didn't have LEDs in already. The front are already LED which means you dont need to bother with the subject that people are preoccupied with on boards. It's already taken care off. Least that's my last thought when I was reading stuff on the top.
Thanks for your crystal clear explanation. I confirm that there is absolutely no difference and the car runs as good as day one.
Thanks for all the the info on this Tell. Just ordered a set to go in my FR Sport.
Obviously a cost saving move by Seat not putting LED's in or having integrated ones as the LEDs on the other half's Leon look great!
Reactions: Tell
They are pretty bright and give you the sharp on and off whilst filaments give you the lazy flash as the intensity drops slowly.
Seat were probably saving something back to put on the next edition like the bar light they hint at on the Tarraco but didnt provide at launch. Reckon it's more staging the designs than cost savings.
Assuming you got the pre LED rear bulbs and want LED....
On face value the ones we previously found which were the Vannasi model but badged as something else were these... currently not available
They were 21SMB equivalent of 850 Lumen.
Looking at the current Amazon suggestion alternatives:
1. These but only 600 Lumens so not so bright as the 850 Lumen upgrade
2. This one 900 Lumens, 33 SMBs
3. This 900 Lumens, 33 SMBs
Think I'll pass on the difference between 2 and 3 unless anyone can spot it.
So I reckon on similar output to the original one I posted up in 2017 and again in 2019 rebranded the links 2 and 3 are the equivalent but with 33 light emitting pads to the original 21 SMB upgrade.
Anybody spot the different in 2 and 3 ?. PY21W is the fitting. Amber is the colour and 900 or so Lumens the target brightness. Anything else different in the two links ?.
Similar to the original 21SMB but with 33 SMBs they seem to be branded under different names. Another alternative to 2 and 3 above. It's all branding.
Happy hunting. I bought 4 at the time so I had two spare. 5 years later the original 2 Vanassi are still going strong ✔. Ditto with the high intensity reversing lights, bought two spare. Haven't needed them either but saved re looking. Thing about spares you don't really want to start a search again if one goes trying to find one with the same light output. Suggestions above come with spares. Set of four ✔.
Reactions: Loadmaster748
Ive recently bought some LED indicator bulbs for the rear of my MK3 Leon FR Technology, and yes the add said CANbus compliant. (These ones https://www.ebay.co.uk/itm/374844629873?var=643919950382) The problem is that when I fit the bulbs, I get an error message and they dont flash. Ive been told that I need to fit resistors with the bulbs. Can any one tell me what size resistors i need please as there seems to be many different ones. Many thanks :)
With the Ateca the front are LED already so the fabled resistor is already in the circuit which is why you can replace the rear with LED, suspect that's why.
Called Can Bus resisters.
This might be of use
No such issues with the Ateca that I put down as I said to being already semi LED in the pre face lifted ones. Think you get them on Amazon. I have seen people on Leon threads saying put one in. But we are ok here with Atecas?.
You might want to post the question on a Leon thread.
My Leon also has front LED indicators as standard. the bulbs I purchased said CANbus compliant but it looks like they arent. Im looking for help in getting them to work correctly.
Sure it's not the bulbs being fully not upto spec, you might find something on this search on the board:
I seem to recall on the Ateca we only changed bulbs to proven ones that worked lifting the spec from Ateca Spanish and German boards... where I got them from. Was a while ago so if you pick other unproven ones things might not work.
The general can bus spec is to stop the error code coming up but I do recall when people went off the recommendation things didn't work out well. There was a case of someone fitting internal lights to LED and it flashed. Xcellence always had LED internal lights whilst the lower spec Atecas didn't. The dark art of these can bus resistors isn't one I have had experience of. Others do but not on the Ateca unless it's the inside lights of non LED cars :oops:
Hi, I have recently changed my reversing and indicator bulbs to LEDS my interior light now won't turn on when the door is opened.
Could this be related to the resistor question?
I have a Ateca 2019 FR
LEDS bought:
P21w 1156 Ba15s Led Bulb Super Bright White 6000K, with Projector 6W DC10-30V For Backup, Reverse Lights, Stop Drl Lights, Turn Signal Light, Rv Lights (Pack Of 2) https://amzn.eu/d/0f1runNw
GLL 2pcs Amber BAU15S LED Turn Signal Bulbs, 7507 1156PY PY21W LED Canbus, Super Bright 144-3014-SMD 2800 Lumens, Only Used for Turn Signal Light(DC 12V) https://amzn.eu/d/0aDvPKS4
I would have thought no but you never know. The ones I used had the built in resistor.
Sure you haven't fumbled a switch that stops the interior lights going on. Will be up in the ceiling. I never touch those switches myself but it's up there I'm sure. If you put it on for reading you need to get it back so it comes on when the door is opened. Click it too far and it goes in to lovers modesty mode, so the lights don't come on when the door is opened.
The switch gear in the roof varies by model. Panoramic roof has something slightly different to normal.
Nope, both are selected for when the doors open the lights come on but it doesn't appear to be working!
I believe the ones I have resistors in too since they're Canbus error free?
Experimental approach you'll have to swap the bulbs back till you find which set it is. Could be just coincidence. The story is if you have LEDs already in the circuit then they remain error free. In the Xcellence the front were fully LED, the rear wasn't. Probably why they were not fussy. Reversing lights obviously doesn't apply. The ones I fitted were fine.
I just took the ones the Spanish board at the time found to be OK and rolled those forwards as the badging name changed but we're clearly the same manufacturer.
