coilies fitted but knocking
Jun 19, 2007
419
any ideas what the knocking from the rear could be?
the car hasnt be balanced or tracked yet but ive got quite a bad knocking.
jonesya3
603
Liverpool
Did you lower it by the guide supplied with the coilovers or just lower them to what you thought looked good
also are all top mount bolts tight did you replace the front bearing mounts with new ones or use the old ones
Jun 19, 2007
419
this is how low she is at the moment
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Check the top mounts in the boot see if they are tight-there should be 2 bolts on it...1 on top of the metal cup and 1 under.. if ya get me
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Have you used Lithium grease on the topmounts and springs? as this is trait with coilovers..
I have the same systmoms then took them off and greased them up all is fine..
Edit: ignore that...It will be the exhaust going over the rear beam..When its that low...Like mine in the pic it knocks...How i got over this jubliee clip and some Heatwrap...hasnt knocked since..
This is how low mine is and it used to knock...Just check the clearest with the exhaust also is it a milltek?
