st10587 is that picture above before you took the adjuster cup out the rear?
Ive just ordered a set of weitecs bud will get some pictures once they arrive i hope they are here for friday so i can set about them on saturday :lol: (hopefully weather plays its part and stays dry [:@])
the above pic the adjusters are still in. it drops another 10 or so mm with the cups out
adjuster cups out
Before and After
Thats magic st10587 i ended up reading through your thread and found out for myself haha think ill take out my rear adjuster cups as that looks a sweet height [B)]
if your running 20mm spacers on the rear there will be scrubbage on the inner arch liner:cartman:
I bought Weitecs from DPM, and im very happy with em. Just remeber to take the rear adusters out if you wanna go really low.
To be fair it is on a slight slope :D
I do love those pics
thats a great pic! is that 16's you're running? do you think they make much difference to ride height compared to 17's? i'd love a set of 16's if i thought they'd clear my brakes. F2 Stu got 16" compomotives to fit, but he had to grind away some of the caliper which i'm not willing to do.
Yep 16's on there.
What brakes are you running?
Mine had to be spaced out a touch more and theres about 1mm clearence from the caliper to the inside of the spokes.
312mm tt brakes should be a piece of p1ss under most 16's
compare the size of those calipers to mine and you should be fine
Yep 16's on there.
I've got the standard Cupra AP's which are pretty wide, so it's a struggle finding 17's to fit let alone 16's lol. Something to think about I guess, thanks for the info. :)
