Cold start problems, cuts out, p1296 error aswell
mark8
20
Newcastle
Hi guys really needing help here, I have an 05 leon fr 1.8t auq and cold startups a nightmare, I have p1296 coolant system malfunction and I have changed the coolant sensor with no luck, thermostat seems fine it gets up to temp after a few mile and stays there, the car smells like its overfuelling especially through the cabin heaters but my main fault is cold startup it will start up no problem sit at idle nice soon as you rev it up or try to move away she cuts out or coughs and splutters and pops then once revved up a few times shes fine, anyone any ideas I have just bought some plugs to stick in it but I think its mainly down to my p1296 error?
Also have a fault with it dropping boost up the rev range but im not sure if that's linked?
Mark
mark8
20
Newcastle
Drives mint after a few mins, im not ruling out the possibility of a naff sensor as its from europarts and I know what there like,
mark8
20
Newcastle
will check that but would that not just cause it to slowly rev up, I do have a snap on diagnostics which gives me the option of a throttle body reset too
Mark
mark8
20
Newcastle
Mate mine was cutting out and jumping all over the place. An wouldn't idle! I Changed my temp sensor(5min job) and all was well!
Ak
Ive changed the cts though matey but for an aftermarket item from euros which im thinking may just be knackered, ive tried to see if my snap on diagnostic will read coolant sensor value.
It does give a coolant temperature value but I don't know where its reading It from possibly the gauge sensor?
I think I might get a proper sensor from the dealers
Mark
akchappers
3,067
7
Gillingham Dorset.
Could be your aftermarket one is pooped mate!
Believe me it causes masses of problems! Was having to rev mine at least 2500rpm to make it move most of the time and then would tick over( sometimes) at about 450 rom. Sounded awful!
Ak
mark8
20
Newcastle
yeah mine pops and bangs and cuts out, you can tell its overfuelling too, if I unplugged the sensor the cars no different at all but the error code changes to high input so the wiring is ok, I think a trip to the dealers for a proper sensor.
mark8
20
Newcastle
Ah im back to square one, just fitted a new sensor from seat and no luck, still runs rubbish and cleared the code and it came straight back, anybody any ideas whats wrong, im guessing next thing is thermostat, pulling my hair out now
mark
traumapat
Leon Cupra IHI
Jul 24, 2005
5,917
sunny sussex
It could well be sticking. Yes you should reset it once youve cleaned it. Carb cleaner is ideal for this.
Fingers crossed its that as its nice and easy
mark8
20
Newcastle
Hopefully fingers crossed, I meant to do it before I got the sensor and I completely forgot about it, gives me a job tomorrow to do, fingers crossed, thanks
mark
GilMastaG
cupra enthusiast
Jul 25, 2014
68
Staffordshire
Pcv system of the right of.your rocker goin to the underneath of the intake manifold, it gets oily gunk in and cuts out, clean the hoses and.carb clean the pcv, should.sort it out ive jus done mine.and.it runs.sweet, you might want a.catch.can to save you doing it again
mark8
20
Newcastle
Thanks mate il give it a go, I did clean and reset the throttle body with no difference
mark8
20
Newcastle
Havent looked yet mate, trying to get the motivation to get outside and look, got to change the starter on my astra too and my transit needs a new exhaust so its just building up lol, do you have any pics of what to clean out?
Mark
