Cold start problems
Mar 5, 2023
Hello I’m having problems with my pd150 when we I go to start it, it won’t start first time but when you take the key out and do it again it will start up it runs and drives a sourly fine, here’s all the codes even though I did change the crank sensor about 7 months ago after the code first come up thankyou
mty12345
3,771
476
bristol
Coolant temp sensor. It will be causing the engine to use the wrong amount of fuel to start it. Once warm it's not an issue, hence why it starts 2nd time around.
iammooks
1,739
1,131
My PD150 started much better after changing the coolant temperature sensor and it's a cheap place to start from, given they're not super expensive.
Just make sure you have some coolant to replace what you're going to lose when you take the old one out.
