I took a video of what's happening to the car, it can be seen below, sorry about the darkness but hopefully audio will be enough for someone to advise... It's running rough at idle and also has a slight hooting sound...
youtu.be/Z4TVNsfXVGU
I've also got the following fault codes via vagcom:
5 Faults Found:
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
17664 - Engine Coolant Temp Sensor (G62)
P1256 - 35-10 - Open or Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
18080 - Coolant Fan Control 1
P1672 - 35-00 - Open or Short to Ground
17552 - Mass Air Flow Sensor (G70)
P1144 - 35-00 - Open or Short to Ground
Readiness: 0 0 X X X
Any
help greatly received!
