ScottieC
Can anyone tell me where the coolant temp sensor is located on my Leon 18. 20vt.
Just had the engine fault light come on. Diagnosed as engine coolant temp sensor, and I want to check the connections before I go for a new sensor.
Any help greatly appreciated.
Scottie.
on the RHS, above the gearbox
look for a connector with 4 wires running into it that pokes into a coolant hose
Swapped one on a mated Golf recently, 5min job to swap. Unclip pull out, push new one in and replace clip.
Quote from previous thread ...
one electrical connector to remove, one plastic circlip, pull out sensor, loose a bit of coolant, fit new sensor (making sure it has a rubber seal and that the old one is still attached to the old sensor and not stuck in place), refit circlip and electrical connector, top up coolant. Job done in about 60 seconds. Dont forget to close bonnet. ; )
We didnt top up the coolant as it must have lost no more than an egg cup full. Stuff some kitchen roll under it before removing to catch the coolant.
My readings on vag.com shows 93-96 degress,
few weeks ago the temp light flashed when i 1st started my car in the morning.
Will this cause performance problems? how much does this sensor cost around? (may go down to gsf parts)
Hope you guys can help me.
