wicca
111
Hi
Does anyone know where to obtain info about the ADL engine???
I am particularly interested in as to whether the head is like the KR one (better inlet flow, worse exhaust) or like the ABF one ( worse inlet, better exhaust)
also quite interested about cam's ? what type are they?
Can I fit 268 schricks or 276's - what will work better and what gains do I expect?? I use the car as a daily driver in heavy traffic
Oh and some reliability question ..... My car has done 270 000kms and gives the ABF (in a Golf) a very strong fight :):):) no oil cons over 10 000 km :):):) :thumbup: :worship:
another strange thing about performance - ABF is said to have more torque and good power low down but a second gear rolling start from 2'000 rpm proves that wrong !!! I gain about a metre till 4500 - 5000 and then I loose 3 meters (that;s in second gear) to 7000
I am yet to change the fuel pump - it is on the way out ....and there is a slight hesitation sometimes above 5000 rpm
Never had a better car in my life :thumbup:
Pic's soon and sorry, greetings from bulgaria :cheers:
i have had adl in an ibiza and now run an abf powered cordoba,the difference i have is at top end the cordoba reaches better top speed,and is slightly quicker getting there,not a great deal in it.
on the rolling road the ibiza had 145 bhp the cordoba has 157 bhp,torque figures i can't remember,but can find them if you are interested
1.8 16v Cordy SX? Blimey, don't think we got those over here in the UK.
Anyways, i'm sure I recall reading somewhere that an ADL was basically a KR with Digifant management - all KR applications used K-Jetronic mechanical injection as far as I know. Happy to be proven wrong by someone with ETKA in front of them tho :)
Yes I thought as you did - but got totally confused not so long ago - see, the KR uses a very strange head cover gasket the head and cover have grooves to accept some sort of bulges in it whereas ADL's is like the ABF's - found that the hard way
I have heard of three types of manifolds (inlets) - 42 45 50 mm.......and two types of exhaust manifolds - 4 into one - and 4-2-1 :):):)
Got confused already??? Me too
There is a significant difference between a KR head and an ABF one:):):)
where does the ADL belong????
not that it matters much to me - I love my car - SACHS -30mm susp - body coloured bumpers spoiler and sideskirts , and oh I am still drooling when I see my car - OZ F1 grey 7x15s......
Will look for more go next summer - still choosing the best way to achieve it ....
PS. got an FK Auto cone filter - when the thing comes on-cam at 4000rpm sharp - the noise is unbelievable :coolthumb - I like the looks on BMW, Astra drivers, and rececookers...there are about 6 SX in total (only one ABF az far az I know) :) in Bulgaria
how come 145 ??? It is rated at 130brake???the adl....
they are slightly better than the book states,it had done 80km i think,plus i had a sheilded inductuion kit,cold air feed and a straight through exhaust without the cat.
I am w/o cat as well - I can have a custom made 4 into one but don't know how long the branches should be:(
I've seen different designs - and don't know which is best for a relatively std car
ask robT he has a tubular manifold on his ,i'm not sure but i think its 4-1 ,try the search button he has commented on it before
wicca said:
...I have heard of three types of manifolds (inlets) - 42 45 50 mm.......and two types of exhaust manifolds - 4 into one - and 4-2-1 :):):)
Got confused already??? Me too...
LOL, yeah, VW engine codes are funny old things aren't they? Some changes to a particular engine seem to warrant a new code, whereas others do not. :givein:
I tend to dabble in older 8v motors, if you want to see variety consider how many different variants of the DX motor there are - how about non-hydraulic or hydraulic tappets, regular or air-shrouded injectors, oil-air or oil-water-air oil coolers, and so it goes on... And that's before you get on to stuff like manifolds, there are several exhaust manifolds for a DX motor that I know of...
BTW - it's not uncommon for VAG motors to put out power figures a little over "book" - but a little tweakery can help improve matters too :)
my abf engine broke a cam, tappet,belt,pully etc and ended up junking it and going for a kr head with kr cams etc, every item in the head was vw kr parts except for head bolts and the kr rocker gasket is indeed different beside the abf item.
There are other differences mate.....
inlet ports are bigger on the KR , exhaust are smaller .......
I reckon the cams are different , too .....
Not that it matters much:)
I have read somewhere (don't remember where) that ABF flies with an early KR inlet manifold that is ( apparently from a KR w/o a cat) 50mm...... as to your 45mm item.
physically they are, the rears of the lobes are narrower but all in all they perform very similarly. flow job is next on the cards for moi!
I am considering lightening and balancing of flywheel and crank, mild port & polish (DIY), cold air induction (DIY), and I'm yet to choose 268s or 276 Schrichks......The last is a very tough decision as I do a lot of downtown driving and need more lowdown torque....rather than top power
280mm G60 discs and calipers are on the way as well as braided hoses....Need the braking power ;)
Help......
:blink:
my car i sick...........went to the local dragraces last weekend.......
no power after 5000 rpm..... a silly mk1 GTI 1.8 had a car's lenght all through........
I made a near perfect start and had 1/2 a car before changing to second.....
I am totally gutted :-o
'new spark plugs , distributor cap, car runs fine before reaching operating temp, after that doesn't want to rev .... one possible cause is the FK filter I use - heat soaking???? I have no idea :hide:
your not missing are you? i left a lead off mine when i wsas replacing my plugs, car starts and idles fine but theres not upper revs power. as soon as i put lead back on, it revved freely.
no, mate....
It's down to a knock sensor failure - got the car to my friends garage to check for error codes and a message appeared "knock sensor - no signal" It has been erased but I am sure it will appear again:)
Need to change it ASAP....
:whistle:
Car runs fine but this is the second time it's done it.....
what exactly do you mean straight through exhaust???
Oh I had that removed long time ago
yes it makes a bit of difference all through the rev range - I think the greatest benefit is right above idle speed and top end.power.
I was thinking of removing the middle exhaust but was told the car would be far too noisy....... I am saving up for a complete exhaust system (tailor made) including 4 to 1 mani , 2 1/2 inch all the way.
i had a centre pipe with no silencing,and it drove me mad,far too noisy and made little difference to performance,probably non at all.
