cordoba sx coupe '97 broken electric window!
badad
random chants
Apr 11, 2005
65
wolverhampton
is this a common problem? my drivers side window will move about 1/2 inch then jam on its way down, it also struggles to get back up! sounds like its jamming on something! any ideas?!?
Gunga
Sounds like it has come off its runners, wouldn't keep operating it as this may bend the mechanism.
Best to get the door card off and have a look, you should be able to see where it has come off and feet it back.
Best of luck with it :funk:
Gunga
With the door card off and a little light on the subject, try operating the window. You will probably find that it will be easy to identify the problem. I had this problem with my Rover.
Sometimes the wiring can work loose and get in the way of the runners, the window will still operate but will stick.
Hope this helps.
Kev
WeeJase
pert
Jun 2, 2001
8,595
check the cables running in and out of the motor/winder,if one part on this goes ,then bin the lot.
not expensive or difficult to replace(if you know your way around a scrappies ;)
