Mojo_SA
Hi Guys
Im trying to find the exact specs that I should be using as I can find 3 different combinations on the interwebs
60 NM - 90 Degrees (x2) - Backwards Sequence ( outside to inside )
http://forums.vwvortex.com/showthread.php?3425946
60 NM - 90 Degrees ( x2 ) Normal Sequence ( Inside to Outside )
http://forums.subdriven.com/showthread.php?4021540-Torque-specs-and-sequence-for-AEB-Head-Bolts
40 NM - 90 Degrees ( x2 ) Normal Squence ( Inside to Outside )
http://forums.vwvortex.com/showthread.php?5160729-Head-bolt-correct-torque-spec
