pandamin
55
Bucks
Just had a friend fit the creation motorsport TIP to my 1.8T FR. Wondering if anyone else found that it was a very tight fit around a ridged water pipe and one of the gear linkages. So the TIP is in there good and everything fitted, it's just slightly morphed where the pipes are. Think this will create any problems?
I fitted mine to me mk4 cupra and i removed the metal support bracket and moved the pipe a little to fit it caused me issues down the line mind with the pipe coming out of the block a little under the inlet manifold making a small leak of coolant but solved it with a new o ring and some gunk stuff didn't bother putting the bracket back on
Sounds like you got something else going on, haha. Hopefully mine wont have any issues in the long run. didn't need to disconnect anything other than the pipes attached to the the TIP itself. Jubilee clips EVERYWHERE! :)
