Leon 1.8T. stage1 by P-Torque, reversed ForgeDV, blue spring now - same symptoms with a green spring. Crize is concerned his boost may be fluctuating. He logged 115 and 114 to show reguested boost, actual boost and duty cycle.
On a couple of the runs above, I can see a quirk at around 4000-4200 rpm where the boost dips before recovering. See the first run, there's a curious 95% in duty cycle. Overall, it looks healthy to me and actual boost follows requested closely. I don't think there's an N75 problem.
On 114 loads, everything looks hunky-dory.
Code:
Monday 2 March 2009 00:21:16
06A 906 032 SJ 1.8L R4/5VT 0010
Group A: '114 Group B: '115
Engine Load Engine Load Engine Load Charge Pressure Engine Speed Engine Load Charge Pressure Charge Pressure
TIME (specified) (spec. corrected) (actual Value) Solenoid Valve TIME (specified Value) (actual Value)
Marker STAMP % % % % STAMP /min % mbar mbar
0.54 171.4 150.7 25.6 0 0.24 2000 25.6 990 1010
1.14 171.4 150.7 74.4 95.3 0.84 2000 26.3 990 1010
1.75 172.2 147.8 106 95.3 1.44 2160 87.2 2030 1170
2.35 172.9 143.3 139.1 95.3 2.05 2360 123.3 1990 1590
2.95 172.9 152.2 155.6 76.1 2.65 2680 154.9 2020 2030
3.56 172.2 161.2 172.2 77.6 3.25 2960 153.4 2150 2010
4.16 171.4 170.1 178.2 75.7 3.86 3320 166.2 2190 2090
[I]4.76 169.2 168.7 164.7 95.3 4.46 3680 177.4 2200 2200[/I]
5.37 167.7 167.2 169.2 79.2 5.06 4000 177.4 2190 2270
5.97 166.2 165.7 169.9 85.9 5.68 4360 163.2 2130 2050
6.57 165.4 164.2 164.7 82.4 6.28 4680 167.7 2080 2120
7.19 164.7 162.7 160.2 86.7 6.88 5000 161.7 2040 2010
7.78 163.2 161.2 157.9 95.3 7.48 5280 158.6 2020 1980
8.39 161.7 159.7 155.6 95.3 8.09 5560 157.9 2000 1940
9 160.2 156.7 86.5 0 8.68 5800 154.1 1960 1900
Monday 2 March 2009 00:23:50
28.67 168.4 150.7 85 95.3 28.36 1880 75.9 2030 1030
2 29.27 171.4 150.7 109 95.3 28.97 2000 97.7 2060 1300
29.87 172.2 149.3 131.6 95.3 29.57 2120 120.3 2020 1570
30.48 172.2 146.3 154.9 80.4 30.17 2280 143.6 1990 1860
31.08 172.9 144.8 152.6 76.1 30.78 2440 157.9 1970 2070
31.68 172.9 150.7 151.9 76.9 31.38 2640 149.6 2010 1980
32.29 172.2 155.2 152.6 77.6 31.99 2800 153.4 2070 2010
32.89 172.2 159.7 158.6 78.8 32.59 3000 155.6 2140 2040
33.49 172.2 165.7 163.2 79.6 33.19 3160 159.4 2150 2090
34.1 171.4 170.1 167.7 81.2 33.8 3360 166.2 2170 2110
34.7 170.7 170.1 171.4 82.7 34.4 3560 169.9 2180 2140
35.31 169.2 168.7 171.4 81.2 35 3760 172.9 2170 2200
35.91 167.7 167.2 169.2 82.7 35.61 3960 167.7 2170 2160
36.51 166.9 165.7 165.4 81.6 36.21 4160 169.2 2140 2170
37.12 166.2 164.2 165.4 81.2 36.81 4360 165.4 2120 2110
37.73 166.2 164.2 163.9 82.4 37.42 4520 161.7 2090 2070
38.33 165.4 162.7 160.2 82 38.02 4720 162.4 2060 2050
38.93 165.4 161.2 160.2 83.1 38.63 4880 159.4 2030 2000
39.53 164.7 161.2 159.4 83.1 39.24 5040 160.2 2010 2020
40.13 163.9 159.7 158.6 85.9 39.84 5160 159.4 2010 1970
40.75 163.2 158.2 160.2 89 40.43 5320 160.2 2010 1970
41.34 162.4 158.2 157.9 92.9 41.05 5480 159.4 2000 1960
41.95 160.9 155.2 156.4 95.3 41.65 5640 157.9 1980 1950
42.66 159.4 152.2 154.1 94.1 42.35 5800 153.4 1920 1920
43.26 158.6 150.7 9 0 42.96 5880 127.8 990 1650
81.37 171.4 149.3 101.5 95.3 80.97 2000 80.5 2080 1090
3 81.97 172.2 147.8 129.3 95.3 81.67 2160 115 2020 1490
82.58 172.9 144.8 157.1 78.4 82.28 2320 142.9 1990 1850
83.18 172.9 146.3 149.6 74.9 82.88 2520 156.4 1970 2070
83.79 172.9 152.2 151.9 77.3 83.48 2720 149.6 2040 1970
84.39 172.2 158.2 165.4 76.5 84.09 2920 154.9 2130 2040
84.99 172.2 164.2 159.4 78.4 84.69 3120 166.2 2160 2170
85.6 171.4 170.1 172.2 78 85.29 3360 172.9 2170 2220
86.2 170.7 170.1 175.9 79.2 85.9 3560 166.2 2180 2060
86.8 169.2 167.2 166.2 84.3 86.5 3760 169.2 2170 2090
[I] 87.41 167.7 165.7 170.7 78.8 87.12 3960 174.4 2170 2240[/I]
88.02 166.9 165.7 167.7 83.5 87.71 4200 162.4 2140 2050
88.61 166.2 164.2 162.4 80 88.31 4360 169.9 2110 2170
89.23 166.2 162.7 164.7 82 88.92 4560 160.9 2070 2050
89.82 165.4 162.7 159.4 82 89.53 4760 161.7 2050 2060
90.43 165.4 161.2 161.7 82.4 90.13 4920 160.2 2030 2010
91.03 164.7 159.7 159.4 83.9 90.73 5080 159.4 2010 2000
91.63 163.9 159.7 160.2 86.3 91.33 5240 159.4 2010 2000
92.23 163.2 158.2 159.4 87.1 91.94 5400 158.6 2000 2000
116.37 172.2 146.3 25.6 0 116.07 2200 24.1 990 1010
133.98 172.2 147.8 107.5 95.3 134.28 2320 124.1 1990 1610
134.58 172.9 144.8 140.6 95.3 134.88 2600 155.6 2000 2060
4 135.18 172.9 150.7 156.4 75.3 135.49 2920 154.1 2130 2000
135.79 172.2 159.7 167.7 77.6 136.09 3280 163.2 2170 2090
136.39 171.4 168.7 179.7 79.2 136.69 3640 174.4 2190 2150
136.99 169.9 168.7 169.9 89.8 137.3 3960 181.2 2200 2300
[I]137.61 167.7 167.2 171.4 78.4 137.9 4280 163.2 2150 2040[/I]
138.2 166.2 165.7 173.7 88.2 138.5 4640 172.9 2090 2140
138.81 165.4 164.2 169.2 80 139.12 4960 160.9 2050 2000
139.41 164.7 162.7 160.9 85.5 139.71 5240 161.7 2030 1980
140.02 163.9 161.2 158.6 91 140.32 5520 158.6 2020 1950
140.61 161.7 158.2 156.4 95.3 140.93 5760 155.6 1970 1910
141.23 158.6 155.2 151.9 95.3 141.52 6000 150.4 1940 1860
Monday 2 March 2009 00:26:58
0.01 171.4 150.7 72.9 95.3 0.3 2080 88.7 2050 1160
0.6 172.2 149.3 103.8 95.3 0.91 2200 118.8 2010 1540
1.21 172.2 147.8 133.8 95.3 1.51 2360 147.4 1970 1900
1.81 172.9 144.8 157.9 76.5 2.11 2560 152.6 1990 2000
2.41 172.9 147.8 148.9 76.1 2.71 2760 149.6 2060 1990
3.02 172.2 153.7 154.9 77.6 3.32 2960 157.9 2140 2060
3.62 172.2 159.7 160.2 80 3.92 3200 164.7 2160 2130
4.22 172.2 165.7 166.2 80.8 4.53 3400 168.4 2170 2160
4.83 171.4 170.1 172.9 81.6 5.13 3600 175.9 2170 2180
5.43 169.9 168.7 172.2 80.8 5.73 3800 169.9 2180 2150
6.04 168.4 167.2 172.9 82 6.34 4040 171.4 2180 2180
6.64 167.7 165.7 166.9 82 6.94 4200 168.4 2140 2140
7.24 166.9 165.7 166.9 80.8 7.54 4400 165.4 2100 2110
7.86 166.2 164.2 162.4 81.2 8.16 4600 163.9 2060 2080
8.46 166.2 162.7 162.4 80.4 8.75 4760 159.4 2040 2040
9.06 165.4 162.7 160.9 82.7 9.37 4960 160.2 2030 2030
9.67 165.4 161.2 158.6 83.1 9.96 5120 159.4 2010 2020
10.26 164.7 159.7 159.4 84.3 10.56 5280 158.6 2010 2000
10.86 163.9 159.7 159.4 86.3 11.17 5440 158.6 2000 2000
11.48 163.2 158.2 157.9 88.2 11.78 5560 157.1 1990 1970
12.08 161.7 155.2 157.1 93.7 12.37 5720 154.1 1970 1930
12.68 160.2 153.7 151.9 95.3 12.99 5840 152.6 1930 1920
13.29 158.6 150.7 150.4 95.3 13.58 5960 150.4 1920 1890
13.89 157.1 147.8 147.4 95.3 14.19 6080 146.6 1790 1830
14.49 154.9 146.3 147.4 87.8 14.79 6200 145.1 1680 1840
