May 28, 2020
hello, I am asking for help and advice
The car is Cupra 1P 2.0 tfsi cdla R310
When I put it in neutral while driving, RPM drops to approx. 450 rpm and fluctuates for a while, then stabilizes at 800rpm.
when the car is stationary, the revs do not fluctuate.
no engine code
I added two videos. When the car is driving. And when the car is stationary. I also added a short vcds log. Go kiksu.net/vcds-graph/ and see the log.
I changed:
1. NGK iridium BKR7EIX
2. APR COIL MS100208
3. GFBDVT9451
4. Proram 90mm oversize intake
I cleared the MAP senzor. Without a change
Any ideas? I have a vcds diagnostic. I can make live data.
Thanks for help
  • LOG-01-057-015-018.csv.zip
I would be checking there are no air leaks after the air flow sensor. As I had bouncing revs one time and it turned out the intake pipe had come loose after the air flow sensor spoiling the air the engine thought it was getting.
