Jan 21, 2022
This message is coming up on the car screen (Cupra Born 2023) when trying to connect to Cupra Connect. Has anyone experienced this and how did you resolve it?
Try to set the privacy to minimum then make an attempt to restore the factory settings of the infotainment system.
Failing that, contact the cupra connect team and have them remove the fleet administration and reset the system.
Well the similarity is to where update rights have been taken away from office computers where they dont want you messing about with them and you get group updates administered by the administrator. No second Tuesday of the month in the evening hitting update. Probably doesnt help but a flags been set so you can't get into it. Whether you can turn that flag off yourself is probably debatable via a reset. Might be done on the ID of the unit. This one is going to be an interesting one to watch.
Used image recognition on that screen and Googled it. Google AI says:
If you want to regenerate it and follow the AI links then its this:
I updated that link above so the paste went in correctly. You got links on where it's taking the AI answer from. Probably correct since it's straightforward for AI :rolleyes: .
Saying that AI answer might not reveal totally where it's getting the information from. I see there is a workshop tag that affected some SeatCupra posters in the past where the car showed it was in the "workshop". Some dealers stumbled with trying to sort that one out, others didn't. My research training.
I know 🤣. It's going to be a central toggle that dealers or Fleet managers needs to flick. Don't think a simple reset in the unit will work myself. I wondered whether this was what James was hoping to see from the VIN. Question is when do they become a Fleet car, after leaving the factory not a build code. So there will be some Connect services management function. The AI answer suggested out of connect services contract so if second hand you could find you got a locked down car where the contract needs to be renewed. It could ofcourse just be a scrambled byte in the unit that flicks the switch to make the unit think its got a Fleet car. Where the reset comes in. Privacy setting important. Never play the hiding game. It will get you in the end.
Just adjust the Privacy setting as said, factory reset although they can create more issues than solve. Then its the toggle. You'd think the workshop toggle which can get set may be somewhere near the Fleet managers toggle in screens ?. But then a Fleet manager wouldn't want a dealer playing with that so perhaps thats well away from what a dealer can do. A nose around that. Then it's an upward referral to the experts in MK.
The joys of mib2 no issues like this and no ethernet back bone 😉.
