cupra discs question?
OFX
hi people i was wondering i like the discs on the 911 and i was wandering if any one know where i can get similar ones for my 57 plate cupra from?:confused:
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
If you mean drilled discs then you can buy them from most brake companies like EBC, Mintex, Brembo, Black Diamond etc. You need 312mm ones. Remember that they are more prone to cracking, being noisy, wearing down pads and costing 2-3 times more than a non-drilled disc. Drilled discs are usually only advised for race use..you might be better off with slotted/grooved discs but each to their own :)
Ric 2001
Need an ID-ten-T form
Got drilled and groved on the front and rear of the car Tarox Jap sports.... the rear sounds the worst when applying the brake.
Fronts where about £200 and the rears where about £120.
Just about see them in this pic...
OFX
thank you but
thank you guys for the info but i know the ebc but they dont look as nice as the 911 ones i want similar ones to the 911 ones and is it that bad the sound for the drilled one if so can some one explain why u dont here it that bad on the 911 or the merc sl 55 amg because when driving them i dont here it.
