caddyrage
Nurburgringer!
Jun 26, 2008
95
Ellington, cambs
Hey folks
just fitted cupra headlights but dip goes off when full beam goes on
just done a search and found a post saying to wire up a separate loom and relay to keep the dipped on.
well i still have the cordoba cupra my lights came off here so was wondering what position on the fuse panel is the headlight relay
perhaps just swapping that will sort my lights out
cheers, lee
I think mine does this as well. It switches over from dip to main. If i hold the stork just before the click i have both but once it clicks i lose dipped and go to main. Thought it was normal, cant really notice any change in brightness
Definately not normal bud as i tried a headlight back in the cordoba and they work fine.
The loom looks the same so i guessing theres something slightly different at the fuse panel.
have you tried swapping the main beam relay? just had a look in my handbook and it doesn't say which one, but I will check tonight in the workshop Manuel.
