Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
That's remapped - bone stock standard would be 160-170g/sec
this is how it reads
5720rpm - 213.61
5960rpm - 218.75
6200rpm - 220.5
6400rpm - 224.03
6600rpm - 225.78
so that shows that yeah maybe the 225.78 was at the end of the gear change but there is a 224.03
LCR Mat?
Are you sure he's logged a consistant 225g/sec - or is it just the last reading of the run? You do often get a blip when you lift off.
Certainly looks sustained then, but I it makes wonder if he's got a problem - over-reading MAF for example, but maybe it's just his spec?
What's his spec?
5720rpm - 213.61
5960rpm - 218.75
6200rpm - 220.5
6400rpm - 224.03
6600rpm - 225.78
Yes it was 225, I have probably done about 100 logs now with my Leon CR and Audi S3
My spec is Revo ST 2, Blue flame DP, 100 cell cat and system, Pace FMIC(the best), Neuspeed P-Flow intake and smoothed Maf housing.
The maf must be ok as at the RR day the weekend I was told I had the best and perfect fueling out of most of the cars run
Based on Ben posting one figure, I was simply pointing out that it's very possible to get a blip in a MAF log when you lift off. Having done so many logs, you'll know this.
Ben has posted a few "I'm dissapointed" type threads backed up with vag-com figures in the past, he could've been comparing his g/sec with the 225 figure and searching for reasons why his was "low".
225g/sec*1.31(IIRC) = 295ish BHP. What did it make at the RR day you went to?
I haven't logged that many Stage II cars, but I'm fairly sure they don't often pull 225g/sec - good on you if yours does.![]()
