Cupra R Bumper Inserts
Axu
16
16
Sure
cupra300uk
281
104
It s an easy job , you need a friend and some patience, the fog lights grill don t have any screw , try turning your wheel max left and right , unscrew the mud protectors and you get acces to the back of the fog lights grill , it has 2 pins that you have to push and another guy to pull the grill and it pops out ( i ve circled you where you find them , 2 on the left and one behind that radiator ) , after you ve done that unscrew the fog light and take it out , unplug the cable and put it behind a plastic ( you will see in the photos bellow ) then you will mount the new grille and that s it
Me and my friend are struggling at the moment but it’s a work in progress
Reactions: donoli74
CupraNJ
110
40
Bristol
Been a while since I’ve used this but always found useful advice on here so hopefully will get it again!
I’ve recently bought the Cupra R bumper insert (or whatever they’re called!) and wanted to change the copper colour to match my Monsoon Grey. Does anyone know anywhere that would be able to paint this for me? I’m located in the midlands but could travel if not too far. Ideally I don’t want to get it wrapped and I doubt there is a wrap colour of monsoon grey. Bit of a long shot I know but thought it might be worth an ask on here!
Has anyone else fitted them, and if so what do you do with the fog lights? cheers
Could you please share the part numbers for these. Thanks.
Reactions: Glennc91
Glennc91
200
98
Would love to have part numbers and a price for these please, Will definitely be doing this on mine asap.
Glennc91
200
98
I've tried searching 'Cupra R bumper inserts' with no luck. Do you know how you found them in the first place and did you get them from the main dealer? Thanks
Damo H
Oct 3, 2012
4,515
2,705
Car Length In Front
I got them nearly 18 months ago now when they were hard to get. Now any dealer can order them as they're no longer classed as a limited edition part.
Reactions: Glennc91
Damo H
Oct 3, 2012
4,515
2,705
Car Length In Front
I would seriously consider those IF they didn't erase the (very helpful as AFL) fog lights.
Can't say I've ever missed them, but if you look at an earlier post you'll see someones managed to keep them.
I had a proper look (and messaged the guy) and don't think the effort is worth it based on how much you'd need to cut out.
Reactions: Glennc91
