PM’d youI fit it with fog lights. You have do a "little" cut with dremel ?
When I considered doing this myself,, it looked like you'd not only need to cut the grill, and the gloss painted black plastic that sits behind it, but you'd have to cut into the surround itself, was that the case?I fit it with fog lights. You have do a "little" cut with dremel ?
No different bumper and fog light setup entirelyWill these fits on a cupra 290 pre-facelift? I have no fog lights, only grills
Hi Novus,I fit it with fog lights. You have do a "little" cut with dremel ?
Thanks for the reply mate, really appreciate it!I cut piece by piece ? until it fitted exactly ?
One picture below Im done when Im fitted inserts. Second its when Im finished with dark PPF
Fog light actually attaches to the bumper not the grill. The Grill just sits around it.Interesting. Can you remove the foglight from the original grilles without taking the whole lot out? Thinking of removing just the fog light and then using it to cut the cupra R grills before trying to swap them over.
Would it be possible to take a close up photo from the bottom angle?I cut piece by piece ? until it fitted exactly ?
HiBeen a while since I’ve used this but always found useful advice on here so hopefully will get it again!
I’ve recently bought the Cupra R bumper insert (or whatever they’re called!) and wanted to change the copper colour to match my Monsoon Grey. Does anyone know anywhere that would be able to paint this for me? I’m located in the midlands but could travel if not too far. Ideally I don’t want to get it wrapped and I doubt there is a wrap colour of monsoon grey. Bit of a long shot I know but thought it might be worth an ask on here!
Has anyone else fitted them, and if so what do you do with the fog lights?cheers
Did you look at my post above? They are gloss black/copper as standard, and the part number/price is in the link!Do these come painted copper.
I've just picked up a Cupra R ST and could do with refreshing these.
Do you have cost and part number
No problem - if it's just paint damage/defect, they can probably be repaired.Sorry no. Just read the first page. Didn't realise the thread was so long. Thanks.
Just a bit excited by my purchase. Will be popping a few question up later.
Did you cut around the cupra r grill so the fog light slides in?I cut piece by piece ? until it fitted exactly ?
