DAB radio station logo’s
IanH72
301
126
Does anyone know how to get the station logo’s displayed on the preset list? The only station showing a logo in my list is radio 1 but I have Kiss, Capital & Kisstory in my presets with no logos.
manji
190
30
Portugal
You can add custom logos if you want.
Just put the image in a USB stick and select the image you want for whatever radio station.
Sent from my MI 4LTE using Tapatalk
Simon Barker
75
13
Yes I did all of mine found all station logo on internet and stored on memory stick really easy five min job
Bedlam
868
236
North Yorkshire
Download these http://infotainment.phonostar.de/images/vwag/eur/GBR.zip
How to install the logos on your system:
1. Simply save the file to a directory of your choice with a click on the link below.
2. Unzip the zip file and search for the relevant logos.
3. Copy this to an SD card.
4. Then, connect the storage medium to your infotainment system.
5. Now you can import the desired logos into your device.
6. To do this, tap the Setup button and then tap Sender logos.
7. Now tap the desired station button to which a logo is to be assigned.
8. Select the source on which you saved the image (e.g., SD1) and select the logo.
9. Repeat this process for other logos, and return to the main radio menu by pressing the radio button.
10. The SD card can then be removed.
Reactions: Barrington2k
tt3
If there are additional radio stations that you can't find a logo for, this site is a good source: https://media.info/uk/radio
On each radio station information page, there's a link reading "Get a logo for your VW car radio" which gives you an image you can save. The radio screen looks a lot nicer with all the logos populated!
Reactions: betamazbandit
IanH72
301
126
Thanks for you help. I will have a look at the above site and download the logos I need.
