Download these
http://infotainment.phonostar.de/images/vwag/eur/GBR.zip
How to install the logos on your system:
1. Simply save the file to a directory of your choice with a click on the link below.
2. Unzip the zip file and search for the relevant logos.
3. Copy this to an SD card.
4. Then, connect the storage medium to your infotainment system.
5. Now you can import the desired logos into your device.
6. To do this, tap the Setup button and then tap Sender logos.
7. Now tap the desired station button to which a logo is to be assigned.
8. Select the source on which you saved the image (e.g., SD1) and select the logo.
9. Repeat this process for other logos, and return to the main radio menu by pressing the radio button.
10. The SD card can then be removed.
