Yeh maybe not him then! Just try a few bodyshops sure they'll be someone who will do a decent job
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Danny could you get me a pic of this route in the light? I have the LCR chargepipe, but thinking of making it totally MIG welded custom job, but not sure if I'll weld 2 ports in the chargepipe for N75 and DV, or run it from elsewhere as you have done.
Group A: '002 Group B: '020
RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME
MARKER STAMP /min % ms g/s STAMP CF CF CF CF
0.01 2320 9 1.23 4.19 0.38 0 0 0 0
0.89 2440 57.9 6.97 28.75 1.29 7.5 4.5 6.8 6
1.69 2600 63.2 6.56 32.61 2.09 6 3 4.5 4.5
2.59 2800 69.2 7.38 38.5 3.01 6 3 3.8 4.5
3.5 3040 85 9.43 53.06 4 6 3 1.5 4.5
4.49 3400 114.3 14.35 81.06 4.89 6 3 0.8 3
5.29 3800 136.8 18.45 103.94 5.81 5.3 6 3 5.3
6.21 4280 157.1 21.73 130.83 6.61 5.3 6 6 7.5
7.01 4680 157.1 22.55 140.28 7.39 7.5 6 6 9.8
7.79 5040 151.1 22.14 145.03 8.19 7.5 10.5 9 9.8
8.6 5320 145.9 21.73 150.11 8.99 7.5 10.5 9 9.8
9.39 5640 138.3 20.5 150.72 9.79 7.5 10.5 9 12
10.19 5840 136.1 20.09 152.22 10.59 7.5 10.5 9 12
10.99 6080 132.3 19.68 153.92 11.39 7.5 10.5 9 12
,Group A:,'020,,,,Group B:,'002,,,,Group C:, Not Running
,,Idle Stabilization,Idle Stabilization,Idle Stabilization,Idle Stabilization,,RPM,Load,Inj. On Time,Mass Flow,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, CF, CF, CF, CF,STAMP, /min,%, ms, g/s,STAMP,,,,
,0.40,1.5,0.0,3.0,3.0,0.01,3280,49.6,8.20,37.11,,,,,
,1.20,0.0,0.0,2.3,2.3,0.80,3440,90.2,10.25,67.39,,,,,
,2.10,3.0,0.0,1.5,1.5,1.60,3800,146.6,19.68,115.03,,,,,
,2.90,5.3,3.0,3.8,4.5,2.50,4360,163.2,22.55,134.28,,,,,
,3.70,5.3,6.0,3.8,4.5,3.30,4760,154.9,21.73,140.64,,,,,
,4.50,5.3,6.0,3.8,4.5,4.10,5160,149.6,21.32,145.64,,,,,
,5.29,5.3,6.0,3.8,4.5,4.90,5520,142.1,20.09,147.89,,,,,
,6.09,5.3,6.0,3.8,4.5,5.69,5760,136.8,19.68,150.89,,,,,
,6.89,4.5,6.0,3.8,3.8,6.49,6040,132.3,19.27,152.33,,,,,
,7.69,4.5,5.3,6.0,3.8,7.29,6280,127.8,18.45,152.58,,,,,
,8.51,4.5,5.3,6.0,6.8,8.11,6480,123.3,18.04,153.67,,,,,
,9.39,4.5,5.3,6.0,6.8,8.91,6720,121.1,17.63,153.39,,,,,
,10.22,4.5,5.3,6.0,6.8,9.82,6880,115.8,16.81,151.69,,,,,
,0.00,0.0,0.0,0.0,0.0,0.40,3240,59.4,7.79,42.92,,,,,
,0.89,2.3,3.8,6.8,5.3,1.29,3480,112.8,14.76,86.83,,,,,
,1.69,1.5,3.0,6.8,3.8,2.09,3920,163.2,22.96,126.72,,,,,
,2.49,0.8,2.3,6.0,3.8,2.89,4400,163.2,23.37,135.14,,,,,
,3.29,3.8,5.3,6.0,3.0,3.69,4840,155.6,22.55,142.39,,,,,
,4.09,3.8,5.3,4.5,3.0,4.59,5240,149.6,22.14,148.89,,,,,
,4.99,3.8,5.3,3.8,6.0,5.50,5600,140.6,20.91,150.11,,,,,
,5.90,3.8,5.3,3.8,6.0,6.30,5880,135.3,20.09,151.69,,,,,
,6.70,3.8,5.3,3.8,6.0,7.10,6160,130.8,19.68,154.19,,,,,
,7.50,3.0,4.5,3.8,6.0,7.90,6360,126.3,18.86,153.39,,,,,
,8.30,3.0,4.5,3.8,6.8,8.70,6560,122.6,18.04,154.19,,,,,
,9.12,3.0,6.8,3.0,6.8,9.50,6760,118.8,17.63,153.00,,,,,
,9.92,3.0,6.8,3.0,6.8,10.41,6960,114.3,16.81,153.14,,,,,
Yeah i was Just going to do that But my Laptop was deads which i was uber pissed off about.....
How do i set the logs out like the 1st log that i done the the ths cooler....
il go do 118 and 115 now
,Group A:,'118,,,,Group B:,'115,,,,Group C:, Not Running
,,RPM,Temperature,Load,Absolute Pres.,,RPM,Load,Absolute Pres.,Absolute Pres.,,,,,
MARKER,STAMP, /min,°C,%, mbar,STAMP, /min,%, mbar, mbar,STAMP,,,,
,1.04,2960,15.0,0.0,1030.0,0.54,2920,31.6,980.0,1010.0,,,,,
,1.84,3160,15.0,0.0,1390.0,1.46,3040,66.2,980.0,1210.0,,,,,
,2.64,3360,14.0,1.2,1620.0,2.24,3240,73.7,980.0,1470.0,,,,,
,3.46,3640,14.0,1.2,1960.0,3.06,3520,92.5,1110.0,1820.0,,,,,
,4.45,4200,15.0,1.2,2500.0,3.95,3920,142.9,2010.0,2230.0,,,,,
,5.25,4600,15.0,1.2,2480.0,4.85,4400,160.9,1960.0,2530.0,,,,,
,6.05,5000,16.0,1.2,2410.0,5.65,4840,151.1,2300.0,2440.0,,,,,
,6.94,5400,18.0,1.2,2330.0,6.45,5200,146.6,2260.0,2380.0,,,,,
,7.85,5760,18.0,1.2,2250.0,7.45,5600,138.3,2200.0,2280.0,,,,,
,8.65,6040,20.0,1.2,2180.0,8.25,5880,133.8,2160.0,2220.0,,,,,
,9.44,6280,21.0,65.9,2080.0,9.04,6160,131.6,2170.0,2110.0,,,,,
,10.27,6480,23.0,91.4,2080.0,9.87,6360,125.6,2170.0,2080.0,,,,,
,11.15,6680,24.0,93.3,2060.0,10.67,6560,123.3,2160.0,2070.0,,,,,
,12.06,6880,24.0,92.2,2040.0,11.55,6800,118.8,2170.0,2050.0,,,,,
,Group A:,'032,,,,Group B:,'031,,,,Group C:, Not Running
,,Lambda,Lambda,Bin. Bits,Bin. Bits,,Voltage,Voltage,Bin. Bits,Bin. Bits,,,,,
MARKER,STAMP,%,%,,,STAMP, V, V,,,STAMP,,,,
,0.38,0.0,0.0, , ,0.01,0.435,0.435, , ,,,,,
,1.18,0.0,0.0, , ,0.78,0.435,0.435, , ,,,,,
,1.98,0.0,0.0, , ,1.58,0.435,0.435, , ,,,,,
,2.78,0.0,0.0, , ,2.38,0.435,0.435, , ,,,,,
,3.58,0.0,0.0, , ,3.18,0.435,0.435, , ,,,,,
,4.38,0.0,0.0, , ,3.98,0.435,0.430, , ,,,,,
,5.18,0.0,0.0, , ,4.78,0.435,0.435, , ,,,,,
,5.98,0.0,0.0, , ,5.58,0.435,0.435, , ,,,,,
,6.89,0.0,0.0, , ,6.38,0.435,0.435, , ,,,,,
,7.79,0.0,0.0, , ,7.29,0.435,0.435, , ,,,,,
,8.59,0.0,0.0, , ,8.19,0.435,0.435, , ,,,,,
,9.39,0.0,0.0, , ,8.99,0.435,0.435, , ,,,,,
,10.29,0.0,0.0, , ,9.79,0.435,0.435, , ,,,,,
,11.09,0.0,0.0, , ,10.69,0.435,0.435, , ,,,,,
,11.98,0.0,0.0, , ,11.58,0.435,0.435, , ,,,,,
,12.89,0.0,0.0, , ,12.49,0.435,0.435, , ,,,,,
,13.69,0.0,0.0, , ,13.29,0.435,0.435, , ,,,,,
,14.49,0.0,0.0, , ,14.09,0.435,0.435, , ,,,,,
,15.28,0.0,0.0, , ,14.89,0.435,0.435, , ,,,,,
,16.08,0.0,0.0, , ,15.68,0.435,0.430, , ,,,,,
,16.88,0.0,0.0, , ,16.48,0.435,0.435, , ,,,,,
,17.68,0.0,0.0, , ,17.28,0.435,0.435, , ,,,,,
,18.48,0.0,0.0, , ,18.08,0.435,0.435, , ,,,,,
,19.28,0.0,0.0, , ,18.88,0.435,0.435, , ,,,,,
,20.08,0.0,0.0, , ,19.68,0.435,0.435, , ,,,,,
,20.88,0.0,0.0, , ,20.48,0.435,0.435, , ,,,,,
,21.68,0.0,0.0, , ,21.28,0.435,0.435, , ,,,,,
,22.48,0.0,0.0, , ,22.08,0.435,0.430, , ,,,,,
,23.28,0.0,0.0, , ,22.88,0.430,0.435, , ,,,,,
,24.19,0.0,0.0, , ,23.68,0.435,0.435, , ,,,,,
,24.99,0.0,0.0, , ,24.59,0.435,0.435, , ,,,,,
,25.79,0.0,0.0, , ,25.39,0.435,0.435, , ,,,,,
Group A: '020 Group B: '002
Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Inj. On Time Mass Flow
TIME TIME
MARKER STAMP CF CF CF CF STAMP /min % ms g/s
0 0 0 0 0 0.4 3240 59.4 7.79 42.92
0.89 2.3 3.8 6.8 5.3 1.29 3480 112.8 14.76 86.83
1.69 1.5 3 6.8 3.8 2.09 3920 163.2 22.96 126.72
2.49 0.8 2.3 6 3.8 2.89 4400 163.2 23.37 135.14
3.29 3.8 5.3 6 3 3.69 4840 155.6 22.55 142.39
4.09 3.8 5.3 4.5 3 4.59 5240 149.6 22.14 148.89
4.99 3.8 5.3 3.8 6 5.5 5600 140.6 20.91 150.11
5.9 3.8 5.3 3.8 6 6.3 5880 135.3 20.09 151.69
6.7 3.8 5.3 3.8 6 7.1 6160 130.8 19.68 154.19
7.5 3 4.5 3.8 6 7.9 6360 126.3 18.86 153.39
8.3 3 4.5 3.8 6.8 8.7 6560 122.6 18.04 154.19
9.12 3 6.8 3 6.8 9.5 6760 118.8 17.63 153
9.92 3 6.8 3 6.8 10.41 6960 114.3 16.81 153.14
TIME TIME
0.4 1.5 0 3 3 0.01 3280 49.6 8.2 37.11
1.2 0 0 2.3 2.3 0.8 3440 90.2 10.25 67.39
2.1 3 0 1.5 1.5 1.6 3800 146.6 19.68 115.03
2.9 5.3 3 3.8 4.5 2.5 4360 163.2 22.55 134.28
3.7 5.3 6 3.8 4.5 3.3 4760 154.9 21.73 140.64
4.5 5.3 6 3.8 4.5 4.1 5160 149.6 21.32 145.64
5.29 5.3 6 3.8 4.5 4.9 5520 142.1 20.09 147.89
6.09 5.3 6 3.8 4.5 5.69 5760 136.8 19.68 150.89
6.89 4.5 6 3.8 3.8 6.49 6040 132.3 19.27 152.33
7.69 4.5 5.3 6 3.8 7.29 6280 127.8 18.45 152.58
8.51 4.5 5.3 6 6.8 8.11 6480 123.3 18.04 153.67
9.39 4.5 5.3 6 6.8 8.91 6720 121.1 17.63 153.39
10.22 4.5 5.3 6 6.8 9.82 6880 115.8 16.81 151.69
Saturday 7 February 2009 14:38:28
Group A: '118 Group B: '115 Group C:
RPM Temperature Load Absolute Pres. RPM Load Absolute Pres. Absolute Pres.
TIME TIME TIME
MARKER STAMP /min °C % mbar STAMP /min % mbar mbar STAMP
1.04 2960 15 0 1030 0.54 2920 31.6 980 1010
1.84 3160 15 0 1390 1.46 3040 66.2 980 1210
2.64 3360 14 1.2 1620 2.24 3240 73.7 980 1470
3.46 3640 14 1.2 1960 3.06 3520 92.5 1110 1820
4.45 4200 15 1.2 2500 3.95 3920 142.9 2010 2230
5.25 4600 15 1.2 2480 4.85 4400 160.9 1960 2530
6.05 5000 16 1.2 2410 5.65 4840 151.1 2300 2440
6.94 5400 18 1.2 2330 6.45 5200 146.6 2260 2380
7.85 5760 18 1.2 2250 7.45 5600 138.3 2200 2280
8.65 6040 20 1.2 2180 8.25 5880 133.8 2160 2220
9.44 6280 21 65.9 2080 9.04 6160 131.6 2170 2110
10.27 6480 23 91.4 2080 9.87 6360 125.6 2170 2080
11.15 6680 24 93.3 2060 10.67 6560 123.3 2160 2070
12.06 6880 24 92.2 2040 11.55 6800 118.8 2170 2050
Group A: '032 Group B: '031
Lambda Lambda Bin. Bits Bin. Bits Voltage Voltage
TIME TIME
MARKER STAMP % % STAMP V V
0.38 0 0 0.01 0.435 0.435
1.18 0 0 0.78 0.435 0.435
1.98 0 0 1.58 0.435 0.435
2.78 0 0 2.38 0.435 0.435
3.58 0 0 3.18 0.435 0.435
4.38 0 0 3.98 0.435 0.43
5.18 0 0 4.78 0.435 0.435
5.98 0 0 5.58 0.435 0.435
6.89 0 0 6.38 0.435 0.435
7.79 0 0 7.29 0.435 0.435
8.59 0 0 8.19 0.435 0.435
9.39 0 0 8.99 0.435 0.435
10.29 0 0 9.79 0.435 0.435
11.09 0 0 10.69 0.435 0.435
11.98 0 0 11.58 0.435 0.435
12.89 0 0 12.49 0.435 0.435
13.69 0 0 13.29 0.435 0.435
14.49 0 0 14.09 0.435 0.435
15.28 0 0 14.89 0.435 0.435
16.08 0 0 15.68 0.435 0.43
16.88 0 0 16.48 0.435 0.435
17.68 0 0 17.28 0.435 0.435
18.48 0 0 18.08 0.435 0.435
19.28 0 0 18.88 0.435 0.435
20.08 0 0 19.68 0.435 0.435
20.88 0 0 20.48 0.435 0.435
21.68 0 0 21.28 0.435 0.435
22.48 0 0 22.08 0.435 0.43
23.28 0 0 22.88 0.43 0.435
24.19 0 0 23.68 0.435 0.435
24.99 0 0 24.59 0.435 0.435
25.79 0 0 25.39 0.435 0.435
