thats better:D
how is the TIP going....and you are going down the Methy route as well like Robdon
Yup...Just waiting on the Sealing Bung to arrive and the 90D bend too...Then i can Fit it all together...
Its Defo a Massive improvemnt in size for defo...
I will be going down the WMI soon but got my Wot box & 2 step launch controller to keep me busy for a while...
Danny have you discovered some secret power of the gt2x to cope with it's 500bhp filter ;)
Yeah Curzon said i should see the 210g/s to 225 g/s so make it around the 280bhp and 299bhp mark...
But then again its estimates...Im happy ive found my restriction tho...just need to get it all on the car nad log it..
I could be barking up the wrong tree here, but g/s is read by the maf so how is a larger TIP going to increase your g/s when the maf is installed before the TIP? The filter may give you abit but not that much.
How restrictive if the standard TIP, when you put a Forge TIP on you get a better g/s straight away, so in theory Danny's 3" TIP should work better as its allowing more air to pass past the MAF
Shockingly i agree with Danny on this one :blink:
But the MAF is before the TIP, so the air will be read by the MAF and then down into the TIP.
Ive read and proven myself you gain more g/s with better filters but dont think ive ever seen anything about g/s being incresed by a larger TIP?
But the TIP is still allowing more air in
Think about it like this. If you had a small straw in a drink and sucked at the straw, you will get a small amount of drink through, but if you put a bigger straw in the same drink and suck at the same rate your gunna get more drink as the straw allows more to come through
Best way i can think to explain it
Yeh i understand your logic but i also get were Danny's coming from. It should increase his g/s through the same principle of a standard TIP to a Forge one, but obviously the logs will show us by how much. I personally think it should get miles better as his filter was too restrictive to start with and making the TIP bigger should just finish it off nicely :D
