Did you say you had a rich/lean gauge Danny? Are they any good? Easy enough to install?
Danny's great at wiring![]()
lol hence why ul be wiring these bad boys in at the weekend...
Afr is Simple enough todo just abit of head scratchin at the Colours lol as the instructions are utter crap...
I put them there as i didnt want them all on 1 side...as on the drivers piller il have boost,afr & EGT....
Seems certain sizes only fit in there as its 55mm deep and the gauges are 50mm...
change the fuse holder m8 its been know to melt or set on fire
I still think its the battery fuse holder mate, if you move the fuse in that side to side the fan will spin. That fuse box is corroded probably becuase its got no lid and its got wet numerous times!
Even if it was the thermostat you said you chucked the old one so we can't even swop it over again to rule it out, so your still going to have to buy one of them just to test it, or mess around trying to get whoever you bought the ECS thermostat off to swop it on the hope its that
Bar putting your fans on a manual switch as a bodge im out of ideas!
If you think of something else we can try, we can look at it properly tomorrow
bypass the fuse holder with a temporary fuse+holder ??- at least it's safe and testing it
The thermostat will work on its own it won't need other ECS parts to work. Al phone you though, be easier
EDIT: Like we said on the phone we'll bypass the fuse box tomorrow so you know for sure. Text me tomorrow and let me know what time you want me to come down
best way to know the water pump is working is when the engine is cold to take off the coolant cap then the top hose that goes in the the coolant bottle hold it were the cap goes and rev the car at around 3500 rpm if coolant comes out of the hose like a mofo the water pump is working as it should be if there is no coolant or its very poor the water pump is gone
Il never give up drinking i love it too much...Plus loud music doesnt help either lol
just don't swap it for marraige and kids - more expensive and bigger hangovers![]()
