how do you take the charge pipe off is it just the to clips? or sumthing hidden at the back cos i want to paint mine?
what are the 2 rubber pipes that connect on to it. what do they do?
2 x 12mm (Ithink) nut's on the 2 brackets, 2 hose cliped hoses at each end, then 2 small pipes at the top near the Turbo these are held on with single use hose clips, be carefull when you refit the small 8mm pipe, dont do the new clip up too tight otherwise the pipe will split.
The 8mm pipe goes to the N75 valve
The bigger one goes to the DV.
