I was told my Leon had a decat on it,and it doesnt, so its going in for some work which requires the downpipe to be removed (subframe dropped to change rollbar) so ive got a de cat pipe to go on, but ive bought the angled lambda extension to fool the car and therefore stop the engine management light coming on.
But where so i put this adapter/fooler thing? does it go in the first hole on the turbo end, or does it go in the hole on the other end?
Ive got a scorpian cat back system on it, its been remapped already but unsure on power, its very flat under 2500 all the power is higher up, going to stick a front mount on it, but are those £200 ebay jobs any good, u get the cooler, pipes and all the bits to fit it? or they not worth it?
was going to get it remapped again as im only down the road from R Tech so wanted to do bits i can to it, it only needs decat and forge valve really but il stick one of those £200 front mounts on it if theyre any good to get a bit more power out of her. Just had a brand new clutch in it so minds aswell
