Hi Guys&Gals !
Took it to SEAT and they ran a VAG on it (free of charge !!!!!) and said it brought up 3 errors:
16486 P0102 035
MASS AIR FLOW (MAF) SENSOR -G70-
SIGNAL TOO LOW
SPORADIC
17544 P1136 035
LONG TERM FUEL TRIM ADD. FUEL, BANK1
SYSTEM TOO LEAN
16891 P0507 035
IDLE SPEED CONTROL
RPM ABOVE SPECIFIED VALUE
SPORADIC
He reset these errors and said that they shouldn't cause any problems. Maybe a little less MPG, but not that i've noticed.
He said that if the light came on again (it shouldn't), but if it did then it was most likely to be the "Lambda Probe in front of CAT". Which would cost me £107.80 + £60 labour + £29.37 VAT = TOTAL £197.17
But that's only if the light comes on again (fingers crossed it doesn't !!)
He also mentioned that they had been having a lot of problems with this kind of thing and it being possibly linked to owners taking the SEAT radio out and fitting their own !!. Some module in the radio acts as a module for the whole system, or something, and that when radios are changed it can bring up sporadic error codes on the display in months ahead !!! - anyone heard of this ????
Also, he asked me to get SEAT to change the water pump if and when they change the CAM belt, and to ask for a NON-SEAT water bottle because on the SEAT ones the lugs are made of plastic, and other makes they are metal and it might as well be done when changing the CAM belt as they are "buggers to get at" !!! - in his own words !!
But credit to SEAT for doing the VAG test for free and charging me absolutely nothing for the print out and good advice !!!!! - SG PETCH, DURHAM - Credit to you guys !!!
Andy
16486 P0102 035
SIGNAL TOO LOW
SPORADIC
17544 P1136 035
SYSTEM TOO LEAN
16891 P0507 035
IDLE SPEED CONTROL
SPORADIC
Andy
