Does Aura Single CD Have Standard Wiring
Gizmo
53
Hi all
Looking to replace Aura CD in LCR.
Do I need a wiring adaptor to fit normal wiring standard for aftermarket head units ?
Like this -
http://www.caraudiodirect.co.uk/pro...d=1305&cadid=481917e646bdd6c6f6197f68fe8abef8
I assume so unless you guys know different.
They also claim you need the aerial adaptor to power up the roof amp - does a LCR have a roof amp. If so I'll buy the adaptor.
They also claim you need the adaptor to convert the aerial lead to normal diameter.
Cheers for the help.
Arctic
466
Newcastle...ish
Yes you need that, also you need a facia plate as the Aura CD in larger than aftermarket size its only about £10 aswell
For the airel booster they say you need on but i haven't got one in mine, mainly because i rarely listen to the radio
Icecavern
6,214
Berkshire, UK
www.icecavern.com
The wiring adapter just swaps the ignition and battery over and makes sure you have nothing connected to the Kline pin. I've never used one.
If you want the radio to work then it's best to use the booster though.
Pete
