atreyu
38
Hi all,
Can anyone tell me if its possible to get a new plastic bracket which holds the front door modules on? As seen stick up vertically in this pic.... I managed to break the lug when I removed the unit.
Also the module, 3B2837015L doesn't seem common! Apart from one unit from Poland....
anyone tried these?
http://www.ebay.co.uk/itm/SKODA-SUP...031173?hash=item3f3380fd85:g:EzUAAOxyBjBTQbGJ
You don't need one, if your on about the piece of crapy plastic that's on the inmer door to the modual then don't bother you don't need it, mines have all broken off, the bolts in the side of the door holds it perfectly tight.
If not refitting it block the 3 holes on the metal window regulator or water will leak in
