Cant believe people are still having this problem. I fitted the same pipe on mine without it rubbing anywhere.
Only way around it fro what others have said is cut and weld as said above
the very "same" pipe?
same supplier/manufacturer?
yes myki that is the exact one i boughtim going to get it modified as it bangs so badly under the centre section it is rubbing on the bulk head but is worse underneath would welding the extra section in get rid of this or am i better cutting out the 3 flange part and welding an extra piece in there also? thanks
