if you speak to ben @ shark he should be able to talk you through resetting
ive done it by adjusting the parameters to save my customer doing a 300ml round trip
I hooked up vag com and it said the dpf was 56% full and it had been 14670km since last reg, i drove it down the road with vag com hooked up (as if to do a regen) and it switched straight to 0% and the light went out?? Should i be worried?
so this is 5arks so called dpf delete the proper way but still the light returns so the car still thinks it has a dpf NICEEE
I had a friend that removed his dpf and did nothing to the mapping and the light never showed now explain that ?
unless the pressure sensor is still receiving a high pressure triggering the blocked dpf fault to come on wich makes me wonder is that de dpf box restrictive or not done in a very good way and still creating to much pressure and triggering the car to think the dpf is blocking its a clear sigh that there is some restriction going on
