Drivers door rattle
mode
281
North Wales
I seem to have a rattle from the drivers door at slow town speeds where the road is a bit rough, seem to recall reading this somewhere anyone had this ??
JonoUK
385
North Yorkshire
Is it inside the door? Not the jacking point is it?
Thread hijack - I seem to have a rattle on a certain road/surface at various speeds - coming from the rear, sounds like it's AROUND the nearside rear passenger seatbelt... that kind of location/height, but obviously I can't pinpoint it as I only get it when driving at (for argument's sake) 50+ and it's not really the best plan to drive whilst looking backwards into the car :)
Any idea what it could be? It's not the seatbelt, I don't think... sounds like some kind of trim, but around that area.
langy
99
See thread number 5 here it worked for me :)
jlovrek
129
Croatia
try to use co-driver seatbelt... i have that problem... when it's in use, everything was ok, the red plastic where you put and open seatbelt was the problem.
mode
281
North Wales
Hi jonouk it sounds like its (as you sit in the car) the back of the door ie where the latch is, though the noise might be travelling its like the noise an old high mileage car would make when you open the door of an old car though mine does it when the door is closed so dunno iam confused!!
Nov 2, 2006
1,241
Annaghmore
bebo.com
I have a rattle same as first post! only on fough roads and tight right ahnd corners, i seem to think it coming from behind speaker area of door, that area. had speaker out thinking it was the adaptor lead for my new speakers i put in but taped it out of the way and still there!! had inside grab handle off and foud two screws missing from in there, put them in and still the rattle. list growing to go back to dealer!!
mode
281
North Wales
This is so far my first problem the dealer is 35 miles away and taking it in involves time off work etc. Googies if you visit the dealer soon can you let me know if they cure it Thank You!!
Nov 2, 2006
1,241
Annaghmore
bebo.com
i am getting my list drawn up and if have time tomorrow i will ring them to book it in to get looked at. am having a quick look now if i can see/feel anything, taking some of door card of/to one side to have quick look where i think it is? will keep posted on it.
Nov 2, 2006
1,241
Annaghmore
bebo.com
Update.... i may have found it! the window runner seems to have movement laterally (from side to side, towards door skin and back.) am goona foam it up with something and see if it sorts it, does sound same tone and pitch as the rattle, and does take wee bit of force so could explain the awareness of it over 50mph or there-abouts.
