Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Not opening from the inside sounds like child locks??
Try hitting the handle on the outside worked for mine and been fine since.
Might be different as yours wont open from inside either.
Worth a try.
You got door pins? do they go up on the door on unlock?
Sounds like the door lock/mechanism is faulty.
STOP!!!!!!!!!!!!!!
Piece of piss to sort!
Mine did this last week and this is how you can sort it!
1) Pop the plastic cover from the inside handle and unscrew the screws and unhook the door handle
2) pull trim thats below the speaker and then pull the longer length of trim attached
3) Push seat fully back and undo the 2 torx screw in the bottom of the door
4) Now grab the door card from the bottom near the speak and work towards the column(lock side), this should pop off.
5) Give it a tug until the panel can left up.....yes there is sweet fa space but stick with it.....now you need to get the cover off from the side mirror, you might break 1 clip on this but hey it happens.
6) Once thats out now you move the card around until you can get enough space to get the unit free may take a while but relax and slowly wiggle it just a little bit, detach the cables for the light in door and pop it out along with the window switch.......reattach the window switch as you will need this again.
7) Now you should have the card out of the way and the metal section will be visible.
8) Lower the window so the carrier bolts are visible and duct tape front to back through the back window........unscrew the bolts just so that the holder seperates and not to the point where it falls apart! might need to buy some new clips 1 of mine are screwed but superglue is my friend for the moment.
9) Unscrew the bolts holding the metal skin in place
10) Pull all of the wires off from this panel
11) Remove the plastic caps from the door mech unit
12) Now loosen the unit by freeing the unit seal a couple of pulls might help, once this is down left the unit from the bottom, push up and pull towards you........this yet again is a pain so slowly move it once the bottom is from pull the unit down and pull the window mech free.
13) once that is out of the way you will now see the door mech and this is where you have a couple of choices!
a) drill a hole where the securing screw is but this will be visible when the door is opened
b) cut a chunk out of the inner frame that wont be visible i did 5x2 cm section but if you get it right you could probably get away with a 1x1cm section
c) a thin long screw driver or a nokia cover remover which is a metal bar with a small point end, push this through the gap below the nylon clip that will be visible and push hard up.....this is the unit........nylon clip & screw at top is what im on about
http://www.agthompsonfamily.com/vw/DoorLocks3.jpg
I did a combo of b & c once i popped the lock the door opened.
http://forums.vwvortex.com/showthread.php?1542461
The connector and motor is bugger on mine so i brought a brand new unit off ebay for £48 just waiting for it to arrive at the mo or go dealer for £120
Took 2 hours as i was faffing but on a good day could probably take 30-45 mins once you know how to do it.
STOP!!!!!!!!!!!!!!
