Hi
Has anybody had any issues with driveshaft hub nuts coming loose?. Noticed I had a knocking/clunking noise from o/s/f wheel yesterday. Got the car jacked up and removed plastic hub cap and the 36mm hub nut fell out!. Checked everything over driveshaft/ hub etc and splines fine. When I checked the n/s/f hub nut managed to get two turns on it. I've retorqued both sides to 120nm as precaution.
This got me paranoid as if any previous work had been carried out poorly?. Spent then best part of a hour checking major componets/bolts etc case anything else was loose.
