DRL gone yellow and dim
DigitalSushi
147
69
These led strips also work as the indicators.
not entirely sure how they work internally but if there is a short between the drl and the indicator circuit then both bulbs may be activated by the drl circuit but only get half the power due to the short so you end up with a dim orange and dim white combining to make the dim yellowish.
just a thought, could be nonsense though
Jay5959
FR 184
Apr 26, 2020
502
259
Not on the preface lift models they don’t mate, only white drl. There’s a small bulb for the indicator under the strip in the middle of the unit
Reactions: DigitalSushi
Oct 31, 2019
Hello guys, i have almost the same problem.
But to me it seems it is not fully DRL yellow just only some part of it, as you can see in photos.
My Leon is 110k km Face-lift model, so it's going to yellow also when I use the blinker.
Maybe some short circuit ? I'm thinking to do this lights reset from Settings, maybe it will do something.
Some advices ? does it worth to buy new DRL module, or maybe the problem is from inside headlight led tube?
cairus
1,572
552
Completely out of the blue, but maybe the LED driver module for the TFL is defective
cairus
1,572
552
sorry, thought from German. TFL = Daytime Running Light... every headlight has the module for it.
5F0941476
5F0941476
I was thinking about this, but i don't know how exactly works.
Like, is it possible only half of the DRL to be dimmed and the source of problem to be DRL module ??? My logic says no, but i repeat, i didnt check the drawings...
Aug 29, 2024
So i disassembled both and found out there was burned spot on LED module, changed it and not much improvement because also the tube inside has a small burn area, i saw on some videos the guys cleaned it somehow... but the electrician which I went to was afraid to try cleaning it.
Now the burned area is not refracting the light so that's why still dim...
@Noumenon this is applicable also for face-lift modules ? i mean the headlight shell and tube inside?
Noumenon
@callliope DRL boards and tubes 100% won't fit.
Not sure about headlight shell.
You can scrape the burned end of the tube with razor and then polish it.
Or you can try to clean it with a bit of acetone on a cotton ball, it dissolves plastics.
Aug 29, 2024
So actually this is how it's looking on my car:
So I changed the module but still not so much improved, maybe placebo effect.
