DRL Passenger light faulty
Mar 9, 2023
17 minutes ago
Hi there, I have recently had a error come up on my dash saying drl left side not working but it does but flickers, assuming water has got into the control module. Now my question is, if I buy a control module from say ebay, take mine out and put new one in does it need to be coded or just a straight swap? Also how much does it cost to get it coded? I'm based in Reading if that helps
Reactions: JoseKaLeL
SteveGSXR600K1
579
189
I'd swap the modules over and see if the issue goes over to the other light. Then you'd know if it's the module or not.
Mar 9, 2023
Ok will try that first, if it does I take it the module needs changing? Any ideas how much it costs to code new module?
JoseKaLeL
ARONA Beats Audio Edition (2019-Facelift)
Jan 8, 2020
52
Aguascalientes, México
I don’t know un € but at least mine cost like $189 usd when I buy it for my former project but I do not have it install it yet so could you show me where’s located.. I can tell you that you need it coded or maybe search for one of your same car
LeylandVCDS
284
154
Leyland, Lancashire
If you replace like for like, no coding is needed - only thing diagnostics will be needed for will be to clear the historic fault code stored in the central electronics 09 module
