Drone Noise
roundy
134
Hampshire, UK
I have this "drone" noise that's comming from the back end at the moe, sounds like wheel bearing almost but is only noticeable at about 30-40mph. It also sounds a lot slower than a typical wheel bearing noise...?!
Any ideas?
Jun 28, 2001
1,533
when you run your hand over the tyre gently is it bumpy one way smoother the other?? on the tread wearing more on one side to the other
roundy
134
Hampshire, UK
Not too sure, will check over the weekend. If I jack the car up and find no play in the bearings, could they still be shot?
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
id say the wheel bearing as mine was more noticeable between 40-60.. Started off quite quiet but gets annoying soon lol
Also check the brakes arent burning after driving. as said above could also be a stuck brake.. You should be able to feel it though after driving for a bit
