Yep the fuel pressure rail is pumped up along with the turbo boost.
Bigg Addicted, that correct, higher pressure, but less fuel = more power and more mpg! haha
how would this affect a leon with the dsg?
On diesels more fuel= more power
Wrong! Seen about 5mpg increase today while testing it! and that was with planting my foot! Was getting about 37mpg but now getting 42/43mpg since putting the chip on!
True, but also the same amount of fuel at higher pressure gives better atomization meaning a more complete and efficient burn = more power and less un-burned fuel being thrown out the exhaust.
Resulting in using less fuel as your getting more power for the same amount of fuel/revs
I've just lifted this from DTUK's "How it works" page. Note, in the 2nd paragraph, It's says that the box allows MORE FUEL to be injected into the cylinders and you will only see increases in mpg due to having more torque and using less throttle in situations where you would have to use more. It all depends how you drive the car? You'll have to be driving very economically to start with to see any real gains.
How it Works:
Todays diesel engines have many sensors which are controlled by the vehicles ECU these signals are processed many thousands of times in one second to maintain that the vehicle is running at its optimum efficiency and keeping the emissions and economy at acceptable levels.
The idea behind the tuning box is to intercept the signal between the ECU and the injection system usally the common rail and basically allows it to inject more fuel into the cylinders thus producing more torque and power, and because of this the engine is running more efficiently the fuel consumption is also improved because you would have to use less throttle for similar conditions.
Whatever you get, as long as you're happy with it, that's all that counts.
