Yea i had it a lot on map 1+1 since switching to map 2+1 and now 2+2 I hardly get it. So sticking with that for a while. Not even tried 3 but from what everyone else says there seems little point.
184 manual
Been running on 1+2 for some days now, and there seems to be quite a difference betwwen 1+1 and 1+2. Must say i like this map more and more.cant say anything about mpg, but besides being quite fun to drive, the initial impression is that it is a bit bettet than 2+2 and 3+1. Will have to wait until next refill.
I've been logging consumption since the car was new. Unsurprisingly, 1 seems to give a slightly better mpg than 2 which, in turn, is a bit better than 3. Also, again without surprise, +1 is a bit better than +2. But seems to be only a 5% -6% difference between 1+1 and 3+2, so I wouldn't lose any sleep over that. Not tried +3 at all. Very little difference between pre and post box. Usual caveat that no two individual cars are the same.
) anyway, we got back and i brimmed the tank again which cost me £28.50 @ £1.13 so 25.2ltrs or 5.55 gal, Which workes out at just over 59mpg calculated if my maths are correct i dont think that bad at all.
What figures are you actually getting though (mpg wise) when comparing pre-box to post-box?
Good morning guys and gals just a little word I seem to be having some judder in 4th gear and pardon the expression but its starting to concern and piss me off a bit as this is becoming more noticeable about 2 thou + rpm not happing all the wile any body else may have to call Andrew or simon at dtuk as this is spoiling the system
cheers GHB
cheers GHB
Hi Garry, you asked this same thing not too long ago if I remember. The boxes cause juddering when in low RPM and high gear, although it can happen in any gear from what I've experienced (very unlikely in low gears though - 1 and 2).
I think I remember yours is the 150 TDI? So I can't compare directly as mine is the 184 TDI, so unsure if maybe the 150 TDI's cause more juddering with the box than the 184's do. I got quite use to mine and stopping actions which would caused it to judder.
If you're concerned, I suggest you just get on the phone to DTUK and talk to them.
