DV Dumping on idle
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
When my car is just iddling i can hear my standard DV dumping on idle (i think) its a kind of whooshing noise.:confused: :confused: :confused:
Is that normal?:shrug:
The DV seems to be a lot louder than normal aswell, car has done 46K:)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
it couldnt be dumping when idling as the turbo isnt spinning (or at least, not spinning enough) to create positive pressure as the engine is mostly doing the sucking at idle.
have you removed and inspected the standard valve to see if its leaking or damaged?
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
I wouldnt no if it was to tell you the truth ^^^
I thought that about the idling bit and the Turbo not spinning?
What else might it be?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
leak? it could also just be you getting paranoid and subconsciously wanting to buy a forge alloy fmcl007p available from most reputable seat tuners!!
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
Ahem...erm....maybe yes...but....erm.....yeh i do want one of them!!
But do people think it maybe a problem,as the car is still under warrenty i may aswell get a free DV and then it will be ok when i put it back on when car goes...:)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
if its leaking (on boost) yea you will be down on power.
warranty, yea probably. how many miles have you done? they could say its fine though.
RobDon
Pro Detailer
Might not be a warranty item plus it's a very common issue, yes you'll lose power as boost pressure will be leaking through the split rubber diaphragm. £15 and 5 mins will fix it if not under warranty. 46k is actually very good for the plastic Bosch DV to last, they can go alot sooner than that.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you can't have a boost leak at tickover though..
no load, no boost
secondary air pump leak, air con leaking, that sorta thing.
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
Well i may aswell book it in to get looked at,im getting a CD player fitted there next week sometime so ill ask them to look then. Thanks guys :)
