NervEasy
39
10
Hi, Since my 2026 FR ST Leon doesn't have the dynamic turnsignals or the welcome ceremony in the lightbar I was wondering if it would be possible toe replace the rear lights and the lightbar with second hand parts that have this functionality. There are however a lot of different part numbers for these parts. I found a lot of second hand parts on ovoko.fr for reasonable prices but the part numbers are where the search stops at the moment.
Can anyone help me with what numbers do have these functionality?
Sincerely
2026 vehicles have switched to a more secure "backend" encryption, meaning an offline, simple unlock (as was common in 2021) is no longer possible.
Modifications now require a real-time, authenticated session with the Volkswagen group server.
I know about SFD2 but I was wondering if the rear lights would just be powered, so no communication but just power. And it has the dynamic function built-in. I asked my dealer if they can code the functionality in my car but he said no so I assume my lights don't have the hardware to have this function -> that is why I would swap them with older ones?
Sincerely
It isn't plug and play. We can make the necessary software changes remotely for you :)
Sincerely
Hello, I have this issue too but after a lot of research its far too expensive to get the wiring installed. My plugs to the rear indicators only have 4 wires so the LIN communication wires are missing which means just fitting the dynamic LED units wont work. I had some looms made up and fitted a light control module to them. I think they look as near to the real thing as I am going to get. I'd share a video of them in action but this site doesn't allow video uplaods
What kind of control module did you use?
I've just uploaded this video to YouTube showing the conparison. If you slow the playback speed to x0.5 you can see how it works in slow motion.
This is what I used...
I just found this on AliExpress:
LED Tail Lights Dynamic Turn Signal Adapter Harness Blinker Module Kits Fit for Seat Leon MK3 5F 2013-2020 new
P.S. They were installed using genuine multiplugs and wiring to act as a form of bypass/piggy back system. So it means no cutting of any wiring on the car and they can be unplugged leaving no trace.
